Re: '49 H
Posted by Brian in NY on April 13, 2007 at 09:57:29 from (12.149.100.21):
In Reply to: '49 H posted by nballen on April 13, 2007 at 07:21:31:
Run...don't walk....and buy that tractor!
A couple of other points
Most H's don't have 3 pt hitch...you can buy an a/m setup if you really need it.
The loader is factory, and might need some work to get working right, but looks solid and will
lift more than it should. The rusty ram ends are typical, not too much to worry about there.
Almost any working H has assorted oil leaks...don't let that scare you. Most leaks are either non consequential or fairly easy to fix.
Buying lights or repro. lights will cost some money...ask the guy if he has the lights sitting around in a bucket by chance.
You can bolt on a belt pulley if you want, they are readily available.
Lastly...the load when running the hydraulics is normal at low rpm, especially at cooler temps.
Good luck!
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
