carb troubles
Posted by bnelly544 on April 13, 2007 at 19:03:16 from (204.9.234.93):
thanks for the input on my tire question.nowi'm haveing trouble with the carb.it starts and idles just fine but at anything more than a fast idle i have to have the choke on at least half way. i had the carb apart last summer and put a kit in it then and it seemed ok, now the problem is back. i've had the carb off and cleaned out the bowl and checked for water. do the electric solenoids that shut off the fuel when the key is off ever go bad? maybe it lets enough fuel in to idle but not for high rpm?
