Farmall Tractors Discussion Board
Re: Overhauling a Farmall H - How hard is it?
Posted by TMAC on May 01, 1999 at 17:56:27:
In Reply to: Overhauling a Farmall H - How hard is it? posted by Greg M on May 01, 1999 at 16:38:04:
It will depend on how much is wrong with your H. Does it run? And if so does it smoke? I'm mostly a tinkerer and follow the rule: "If it ain't broke, don't fix it". I'm happy as a bug-in-the-rug just to get something that should be junked up and running.
Post a Followup
: Re: Re: Overhauling a Farmall H - How hard is it?
