Re: International farmall museums
Posted by Hugh Mackay on April 15, 2007 at 02:34:04 from (216.208.58.151):
In Reply to: International farmall museums posted by Levi P on April 14, 2007 at 09:29:29:
Levi: Come back and tell us where you live or regularly travel. I can tell you about one just outside Toronto Canada, however if you live south of the Mason-Dixon line it's unlikely you'd be interested. It's at Milton Ontario, much the same format as the one David speaks of in IA. At Milton it's a farmstead setting with each major manufacturer of 50 years ago having a pavilion.
Depending on your approach to the area, directions will vary.
