Re: 300U TA question
Posted by Ben in OH on April 15, 2007 at 09:27:26 from (71.2.200.221):
In Reply to: 300U TA question posted by gleggans on April 14, 2007 at 18:25:26:
My 300U grinds and wont go into gear if the clutch has been released while running in Neutral. My uncle has a 300 w/ a backhoe and says his does the same thing. He says his goes in easier after it is good and warmed up. I've discovered on mine however, if i idle the tractor all the way down, and push the hydraulic lever all the way forward it will drop right into gear. ( the lever I'm referring to switches hydraulics to run loader when all the way back, 3 point when positioned in the middle, and currently nothing when all the way forward) I dont know if this helps, I am new to owning old tractors, but enjoying every minute.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
