Re: 1066 head bolt torque specs
Posted by minnesota red on April 16, 2007 at 18:40:51 from (65.73.95.193):
In Reply to: 1066 head bolt torque specs posted by Adam Kirby on April 16, 2007 at 11:18:41:
i believe it is 165,i can check in the morning and let you know for sure.
if it is for pulling we run them at 190 with stock bolts.
