Re: IH 685-What do I need to know?
Posted by bshannon on April 17, 2007 at 07:07:30 from (72.2.216.253):
In Reply to: IH 685-What do I need to know? posted by Greg Kramer on April 16, 2007 at 21:13:16:
Great little utility tractor. We've had one for several years and as others mentioned, they are pretty maintenance free. Another plus is how easy they are on fuel. One thing I've noticed is that the linkage on the PTO will freeze up if not used for a period of time. This isn't a big issue, some WD40 or such will usually fix this. Ours does not have a torque, depending on your use, the torque gives a better selection of speeds.
