Re: Help with Electrolysis
Posted by NawlensGator on April 17, 2007 at 12:25:46 from (52.128.30.25):
In Reply to: Help with Electrolysis posted by GeneMO on April 17, 2007 at 11:25:47:
I'm thinking you only need a cup or less in 50 gal. The resistance might pretty small in a strong solution which increases amps to the trip point with 12 Volts. 6 volts will give you half the amps which is apparantly within the charger capability. Since you've already paid for a strong solution I would stick with 6 volts. To use 12 V you could dump out 1/2 to 3/4 of the solution and fill back up with water, which makes little sense at this point.
