Re: Help with Electrolysis
Posted by GeneMo on April 17, 2007 at 15:56:13 from (76.0.56.194):
In Reply to: Re: Help with Electrolysis posted by RustyFarmall on April 17, 2007 at 15:31:19:
I bought re bar, then heated it and made a hook to "hook" it over the rim of the barrel, then I welded a short piece of rebar to connect all of the electrodes; I ended up with 8 or 10. A 2x8 across the top, with a hole drilled in it suspends the article in the solution. I get a spark when I connect the ground to the electrode side. I just can't run 12 volt 'cause it trips the reset. I am geting lots of bubbles, even at 6 volt, so I know something is happening. I have the bracket that holds the gauges of a Super H in there.
Thanks Gene
