Re: DT 361
Posted by Tan67 on April 17, 2007 at 18:14:39 from (205.188.116.138):
In Reply to: DT 361 posted by jpsepp on April 17, 2007 at 15:21:38:
Ok heres the setting but make sure the engine is hot when you do the check up because i do not have the setting for the cold engine "sorry" I imagen it would be 2 or 3 thousents less by geussing. or if you could find the setting for a cold one maybe would help.
Intake-.013-thousents(HOT)
Exhaust-.025-thousents(HOT)
I geuss you have a 1206? if so, i warn you the valve cover can be a A.......... to get off if you dont do it just right if the tank is still on. Tan67
