Farmall Tractors Discussion Board
Re: Re: CUB hard to start
Posted by George Koehler on May 02, 1999 at 15:46:26:
In Reply to: Re: CUB hard to start posted by RK Smith on April 18, 1999 at 05:13:09:
The 6Volt Cub is a positive ground system, magneto ignition. It is important that you connect it as a positive ground since that affects performance and life of generator and starter.
You may have already damaged the starter if you were operating as negative ground. That is a simple check at your local generator/starter/alternator repair shop. Also if you connected up as negative ground you may have affected the polarity of the generator. Get that checked as well. The battery/generator system only cranks the engine and runs the lights. The ignition is an entirely separate magneto system which is not connected to the battery.
I would say that trying to convert to 12 volt system would be unnecessary since you can still get the right 6 volt battery.
Post a Followup
: Re: Re: Re: CUB hard to start
