Re: 140 steering question
Posted by Haas on April 18, 2007 at 08:17:55 from (12.65.42.225):
In Reply to: 140 steering question posted by keith stromberg on April 16, 2007 at 13:39:23:
Take the big plug with the hex on it out of the front of the steering box. You'll likely need a big 6 point hex socket of the correct size to get it out. Don't use something that will round off the corners of the hex. Once you get that out, you can turn the steering wheel and screw out the worm. You may have to take the bearing loose at the steering support post near the steering wheel. There is a ball bearing on the end of the steering shaft. If there is any play in it get a new one. There is a castle nut on the end of the shaft that holds the bearing on the shaft. To get rid of the shaft moving in and out as you described, the bearing must not have play, the inner race of the bearing must be clamped tightly against the shoulder on the steering shaft below the worm and when you reassemble, the large plug must clamp the outer race tightly in the steering housing. You may have to add a machine washer of the proper size under the plug to get it to clamp the outer race tightly. Make use the washer contacts only the outer race or it may restrict the bearing from turning. The bearing is cheap, only about $10. If you do this, I don't thing you'll likely need much else. More work on the steering box will require removing the front axle and taking the steering box apart from the bottom.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
