Re: 1954 Super H Hydraulic issue
Posted by herb in texas on April 18, 2007 at 18:17:50 from (69.60.180.88):
In Reply to: 1954 Super H Hydraulic issue posted by Bigstone on April 18, 2007 at 14:34:49:
sounds like the bolt that holds the actuator arm to the pump stroke shaft is loose. Follow the rod to where it connects to an arm and in the center of the arm will be a 3/8s bolt now watch close as you move the rod. if you see it jump here back off to center and tighten bolt. the loader will drop. maybe. Unless you are working with a christmas tree valve.
