Re: How to remove clutch pressure plate on 1944 M
Posted by 44 massey on April 18, 2007 at 19:08:05 from (74.38.134.243):
In Reply to: How to remove clutch pressure plate on 1944 M posted by MattDinMN on April 18, 2007 at 18:26:03:
If you have the bolts out of the pressure plate you can tip the pressure plate and disc enough for the shaft to slide out of the disc to remove it, then the plate and disc!!
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
