Re: Thanks.
Posted by Dave BN on April 18, 2007 at 21:20:29 from (64.12.117.8):
In Reply to: Thanks. posted by A. Bohemian on April 18, 2007 at 17:29:07:
I use steel brake line. It's cheap and bends pretty easy, although it can be tricky getting around the air filter etc. I don't feel safe with rubber or plastic hose as this runs close to the engine and could get caught in brush etc depending on how hard you use the tractor. Steel line (which I paint red) looks more origional also. I use compression fittings which are readily available. Dave.
