Re: How to remove clutch pressure plate on 1944 M
Posted by Nat 2 on April 19, 2007 at 06:54:52 from (64.80.108.53):
In Reply to: Re: How to remove clutch pressure plate on 1944 M posted by MattDinMN on April 19, 2007 at 04:19:44:
Did you remove the 6 bolts holding the pressure plate to the flywheel? It should FALL off the flywheel at that point, as there is nothing else that could possibly be holding it on.
If the bolts are removed and it still won't come off, someone had to have welded it to the flywheel. You'll need to split the tractor and grind the welds off.
