Re: M pulling 3 bottom 16 inch?
Posted by ed1 on April 19, 2007 at 10:01:10 from (198.185.164.128):
In Reply to: M pulling 3 bottom 16 inch? posted by eshoreboy on April 18, 2007 at 17:34:24:
In a word "NO" I think the formula is a little over 1 drawbar hp per inch of plow for the smaller plows and greater for the bigger ones.
2 x 16" is about perfect. 3 X 12" will also work and the 3 x 16" will work in light soil or if you dont put the plow all the way down.
I guess with enough weight and in first gear.
You'll be putting a lot of strain on the M that it wasn't designed for.
