Re: Tires with fluid in them
Posted by Dr.EVIL on April 20, 2007 at 07:41:51 from (72.37.171.36):
In Reply to: Tires with fluid in them posted by edss on April 19, 2007 at 20:02:09:
A 12.4 X 38 has almost 500#/tire of CaCl when filled to the top of the rim depending on how much CaCl is put into the water so a 13.6 X 38 should have almost 600# filled to the same level. According to FIRESTONE's website just the fluid could weigh as much as 581#. The bolt-on weights are 145# plus the hardware.
Whole tractor weight is probably 6000-6500# depending on options.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
