Re: M governor rebuild
Posted by ChadS on April 20, 2007 at 14:25:57 from (65.151.85.25):
In Reply to: M governor rebuild posted by Idaho Jeff on April 19, 2007 at 20:00:38:
Does it still do it if you back the main load adjustment screw all the way out? If it richens up when you make the adjustment, the idle circuit might be plugged up. If nothing changes, you may need to rejet the carb bowls main jet a few sizes larger. I have found carbs that have junk or casting flash left in the fuel ports, and restricts fuel flow to the needle valve, so, check how much fuel is also comming out of the float valve. You can have alot of fuel out of the line, but if its not getting thru to the float valve, it wont keep the fuel bowl full enough, long enough, and drinks it dry. Should be a steady stream, if its a trickle, but good flow out the line, might be another casting flash problem, or plugged. Also, check the vent hole in the gas cap, could be plugged up and it will "vapor lock" Chad
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
