Re: Farmall A Water Pump
Posted by gene bender on April 21, 2007 at 02:58:16 from (67.55.226.214):
In Reply to: Farmall A Water Pump posted by Brent H on April 20, 2007 at 20:19:50:
Yes go ahead with the water pump just be sure it comes with a pulley as not all of them will have a pulley. You dont need to worry about a different radiator or thermostat as it will work just fine with the original radiator. I grind the extra length of the shaft on the pumps down to the hub and you will probably have to do a slight bend on the fan blades to clear the hub of the pump just bend a little where the blades hit the hub.
