Re: H charging update
Posted by gene bender on April 21, 2007 at 03:06:22 from (67.55.226.214):
In Reply to: H charging update posted by Bob Kerr on April 20, 2007 at 19:52:58:
verry simple test on your generator just ground the field and if that makes it charge the reg is bad. If grounding the field doesent make it charge the gen is bad. You dont even have to remove the gen to do the test.
