Re: 1948 Farmall Cub Transmission Fluid
Posted by Phlogiston on April 22, 2007 at 11:39:13 from (68.44.62.53):
In Reply to: 1948 Farmall Cub Transmission Fluid posted by Roger Mcxrory on April 21, 2007 at 17:09:13:
Yes Roger, fill the hydraulics through the plug on the side until it is up to the lip of the fill plug. Replace the plug and work the hydrauliclever back and forth 10-12 times. Remove the plug and top off. Do not try the kerosene trick here. Use Hy-tran or Hy-Tran Ultra in the hydraulic unit.
Phlogiston
