Re: 300 Row Crop Oil pressure
Posted by CNKS on April 22, 2007 at 19:43:46 from (204.249.178.32):
In Reply to: 300 Row Crop Oil pressure posted by jr300 on April 22, 2007 at 16:00:23:
As to the low oil pressure at idle when hot, that is normal as oil pressure, to a certain extent, depends on rpm. As to the higher pressure at idle when cold, that is because the oil is cold and thicker than when hot. However, I think you have a gauge problem, as both the idle and full throttle readings should be higher cold than when hot. Your Operator's manual likely shows the needle over the i as the correct postition. However, if the pump is not worn, and the engine is in good shape, all the tractors I have seen were further over to the right, past the l. With bearing wear, etc, it will gradually move to the left when under full load for a while. That is a 0-75 psi gauge.
