Re: Super A magneto
Posted by Andy Motteberg on April 22, 2007 at 20:50:36 from (4.143.219.145):
In Reply to: Super A magneto posted by Mark2 in Wa on April 22, 2007 at 20:31:52:
It is probably the points, condenser or coil. clean the points and put on a new condenser. I"ve had problems with weak condensers before that make the mag have a weak spark. If not that, try the coil and make sure the magnet has good strength. Andy.
