Farmall Tractors Discussion Board
Re: Super A Hyd. Pump
Posted by bill on May 03, 1999 at 07:05:07:
In Reply to: Super A Hyd. Pump posted by J Risher on April 15, 1999 at 18:50:27:
you might try adjusting the control stop on the hydraulic block assy. Just follow the hyd. linkage forward and you will see adjustable stops. This will eliminate your noise.
Post a Followup
: Re: Re: Super A Hyd. Pump
