Re: 44 M Generator/Alternator belt replacement
Posted by Janicholson on April 23, 2007 at 18:48:10 from (66.173.50.9):
In Reply to: 44 M Generator/Alternator belt replacement posted by Tim Tonjes on April 23, 2007 at 17:59:06:
There is no easy way (unless you find a link type belt of the correct V angle and depth, and make it to fit)
Removing the Waterpump/Fan belt:
There is a square headed set screw on the Fan hub with a lock nut to secure it. Loosen and remove it. (lock nut first) squirt liquid wrench, PB blaster, or favorite juice in the threads, and setscrew hole. Let sit for several days if possible with additional juice. Use a brass punch to gently unscrew the front half of the big pulley, allowing the Pulley halves (shive) to seperate enough to lower the belt enough to get it off the bottom pulley. Then snake a new belt on over the fn, over the hub, under the belt, and onto the Gen pulley (loosened adjustment of course). Then tighten the main drive belt in reverse of loosening. It should have about 3/8" of pretty free slack between the pulleys on tha big guy. Overtightenig ruins the hub bearings. JimN
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
