Re: Plate On Side Of Starter
Posted by Jim Becker on April 23, 2007 at 20:10:28 from (71.164.236.107):
In Reply to: Plate On Side Of Starter posted by SuperA-Tx on April 23, 2007 at 14:15:59:
All the Delco starters and generators had a tag similar to those pictured. 6-volt were black, 12-volt red. The number stamped into the center area is the Delco part number of the unit. Also stamped (I think after the part number) is a date code. I have forgotten how to decode, but you can find it on the web.
For a Super A starter, I have the numbers:
1107067 48-53
1107021 48-53
1107093 52-54
A lot of rebuilders rip the tags off and replace them with their own (usually paper) tags with their numbers, usually something like S-14. That way, they can treat several different original parts as all the same and avoid customer confusion.
