Re: Cleaning 806 Cooling System
Posted by glennster on April 24, 2007 at 08:50:35 from (76.224.16.173):
In Reply to: Cleaning 806 Cooling System posted by chadd on April 24, 2007 at 07:25:37:
i just did the cooling system on my h, it was kinda rusty. went to napa, bought some of their radiator cleaner. drain the system, open engine drains too, flush with clean water on a hose till all the rust is out, refill with clean water, add the bottle of cleaner, let tractor run for a half hour, drain stuff out, flush with clean water , then refill with antifreeze. i bought the premix from farm and fleet, if you mix your own, used distilled water so you dont get all the minerals in the system.
