Re: Cub Spark Problem
Posted by gene bender on April 25, 2007 at 04:13:27 from (67.55.226.214):
In Reply to: Cub Spark Problem posted by Doug1952 on April 24, 2007 at 16:17:50:
You can have all kinds of spark at the points but does the rotor line up with the tower when it fires and does it fire at TDC Your mag or dist must not be in time with piston and or rotor not lined up with tower.
