Re: Cub Spark Problem
Posted by El Toro on April 25, 2007 at 05:09:18 from (152.163.100.197):
In Reply to: Cub Spark Problem posted by Doug1952 on April 24, 2007 at 16:17:50:
You probably need to bring No1 piston to TDC on the compression stroke and then remove the distributor cap and see where your rotor is pointing. It should be at the No1 plug tower.
Even if the distributor has jumped time you should get fire at the plugs. Did it run before
replacing all the new ignition parts? Hal
