Re: M engine rebuild, where to start
Posted by El Toro on March 20, 2009 at 07:56:56 from (205.188.116.73):
In Reply to: Re: M engine rebuild, where to start posted by cessnapilot3@gmail.com on March 19, 2009 at 17:04:50:
Be sure to separate the parts as you remove them. I use cardboard boxes and mark each box what it contains and where it was removed. Even when you clean the parts return them to the same box. I rented an engine hoist from a local rental store and it came knockdown on a pallet and you assembled at your site. They showed how it went together. It was a heavy duty hoist and it would lift that tractor's engine easily. I think it was rated at 2 tons. It had wide casters to provide good stability with the engine raised. Good Luck, Hal
