Re: farmall m
Posted by r4etired on April 26, 2007 at 15:17:50 from (64.12.117.8):
In Reply to: farmall m posted by eric in mn on April 26, 2007 at 08:33:34:
Are you refering to a 9 speed transmission, these were very common on M's and some H's, MandW,Heisler and Behlen made the ones I know about with MW being the most popular. These replacement gears are all in the transmission with no changes in the rear end,Check on your tractor to see if has linkage going in the side of the trans or if it has a cable going in behind the starter
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
