Agreed, 100 Percent
Posted by A. Bohemian on April 26, 2007 at 15:18:32 from (207.170.88.252):
In Reply to: Re: Noisy Farmall Super A Transmission posted by Hugh MacKay on April 26, 2007 at 14:56:32:
Although I'm not sure Bob has a REAL problem (see my posts above about normal gear noise and old tractors), if it develops that he does have a problem, he would do well to consider shipping the removed transmission off to a rebuilder.
I, too, always farm out such work. It's not rocket science, but you rarely get the first one right. It takes experience, and experience is best accumulated on other's tractors! (Just kidding.)
And, I've noticed at least one thread on the Ford 8N boards that started out something like, "Tractor hard to start and won't pull a load. I've checked the gas flow, carb, and spark and they're all good. It can't be the compression because I just rebuilt this engine..."
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
