Re: Noisy Farmall Super A Transmission
Posted by Red Dave on April 26, 2007 at 16:58:16 from (69.139.81.110):
In Reply to: Re: Noisy Farmall Super A Transmission posted by BobMcConkey on April 26, 2007 at 16:24:28:
Bob, These little Farmalls do make a fair amount of gear noise and that is normal. I've been around them since I was a kid and I have a certain expectation, based on years of experience, of what one should sound like. As long as it sounds "normal" to me, I don't even notice the noise.
The problem is I don't know how to describe the sound, or how loud that it is, and I can't hear your tractor over the internet.
I suggest that you find somebody locally who has some experience with Farmall A's, & B's and have them run it and listen to it. It would be a far more informed opinion than anything you can get here.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
