Re: 504 diesel wont start
Posted by the tractor vet on April 27, 2007 at 06:39:54 from (75.19.122.41):
In Reply to: 504 diesel wont start posted by steve turner on April 26, 2007 at 21:02:51:
On the 504 diesel the pump timing is suppose to be 2degrees ATDC but myself i set them at TDC , now are you 100% sure that you are on TDC , pull the valve cover and make sure the BOTH valves on #1 are closed when the timing mark is at TDC , next make sure that the pump is set at TDC thru the timing window . Make sure that all you valves are set corretly . when all that is done Bleed the fuel system all the way thru the injectors. After all this is done RUN THE GLOW PLUGS FOR atleast 60 seconds .Then try starten it DO NOT USE EITHER>
