Farmall Tractors Discussion Board
Re: TD-6
Posted by Ronnie on May 04, 1999 at 05:36:02:
In Reply to: TD-6 posted by Todd on May 03, 1999 at 10:39:53:
The TD6 has the same engine as the MD tractors, so should be able to get the parts for it. On a track tractor the under carrage is the most costly part of a crawler. I would look at the pins and bushings, rollers, idlers, and segments. The TD6 should be worth two to five thousand. You might check the steering brakes and clutches for wear, because they don't run in oil they will wear out fast.
Post a Followup
: Re: Re: TD-6
