Re: farmall M manifold
Posted by DNWELDMAN on April 28, 2007 at 12:23:55 from (64.12.117.8):
In Reply to: farmall M manifold posted by 720diesel on April 27, 2007 at 21:37:34:
Yeah you can weld it. It's cast iron, mig won't work. The rod you want is called "Nickel 99". This is a rod that does not require preheating. Normaly preheating is needed for cast iron. Get it in 3/32" size and run about 90-95 Amps. Make sure it's at least 1/8-5/32" thick to stick weld it. If it's only about 1/16" thick your better off brazing it. Doug
