Re: 350 utility hydrolic problems
Posted by big fred on April 28, 2007 at 21:04:43 from (65.219.141.162):
In Reply to: 350 utility hydrolic problems posted by Tom (The Old Guy ) on April 28, 2007 at 07:07:21:
Tom, when I had my 300U apart and drained and refilled the hydraulics, I found that I needed to prime the system, since the oil has to go uphill a couple inches before it gets into the pump inlet line. The way I primed it was to pressurize the reservoir to about 5 psi using a rubber tipped nozzle from my compressor. Not enough pressure to rupture the reservoir or blow out a reservoir gasket, but enough to get the oil flowing. Worked like a charm. Good luck.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
