Re: disc brakes - super h
Posted by nspec on April 29, 2007 at 17:53:45 from (72.87.118.211):
In Reply to: Re: disc brakes - super h posted by Hugh MacKay on April 29, 2007 at 15:06:54:
Thanks a bunch. I appreciate the advice. Should I use any type of gasket sealer when reassembling the housing to help keep moisture out? The tractor will be mostly idle - I'm just restoring it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
