Farmall Tractors Discussion Board
Re: SMOKE FROM BREATHER ON FARMALL C
Posted by john d. on May 04, 1999 at 08:00:16:
In Reply to: SMOKE FROM BREATHER ON FARMALL C posted by MGill(IL)A on May 04, 1999 at 07:02:47:
Symptom of "blow-by" or combustion gasses leaking past the rings. Sleeve-piston-ring replacement will cure it. For temporary relief, you might try heavier oil, such as SAE 40. If you have LOTS of smoke, you are losing LOTS of power.
Post a Followup
: Re: Re: SMOKE FROM BREATHER ON FARMALL C
