Re: 6 volt regulator for cub
Posted by K-Mo on April 30, 2007 at 14:08:57 from (65.169.189.2):
In Reply to: 6 volt regulator for cub posted by jaw3254 on April 30, 2007 at 13:16:17:
Your old unit would be a "Cutout-Relay" not a regulator. The purpose of the Cutout Relay is to connect the generator to the battery while the engine is running and disconnect when the engine is not running. If your are having a charging problem, you can connect a jumper across the cutout relay with the engine running. If it charges with the jumper installed, the cutout relay is faulty. Other wise the problem is a bad generator or a problem in the field circuit. Connect a jumper from the generator field terminal to chassis ground. If it charges, your field circuit is faulty. The field circuit controls the generator output rate. The field circuit is a wire from the field terminal to the light switch. The light switch has two positions, "H" and "L" representing high and low charge rate. In the "L" position, a resistor mounted on the back of the light switch is placed in the circuit. On the light switch will will also find a second resistor coil. That's for dimming the head lights. For a new cutout relay, try Delco 1116766. K-Mo
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
