Re: B Farmall engine trouble
Posted by Pete in Holland, MI on April 30, 2007 at 14:23:19 from (198.36.89.4):
In Reply to: B Farmall engine trouble posted by Tracy Gruetzmacher on April 30, 2007 at 11:00:25:
Take the gas line off at the carb then turn on the gas, you should get a good stream of gas, not a dribble. Get rid of the in line filter. The sediment bowl is what is supposed to catch the heavy stuff. A screen in the carb catches the rest. The vent in the gas cap is a probable excuse. When you have the gas line off the carb and let a quart run thru it, if it starts to ween off, open the gas cap. Restored flow indicates a blocked vent. What you may have is scale in the tank that covers the inlet of the fuel bowl fitting in the bottom of the tank. Scale is a problem in old tanks. Remove the bowl from the tank and see if any junk has settled in the fitting. If it has, clean & dry, then vacuum the tank as best as you can. After that, find a 3" piece of copper tubing that will fit inside of the fuel bowl tank fitting and solder/press it in. Crimp the top shut and drill a couple dozen 1/16" holes in the copper tube stand-pipe. Sediment will settle to the bottom of the tank, but gas can still be pre-filtered thru the stand pipe and not clog the bowl's fitting. Has cured several tractors I've had.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
