Re: B Farmall engine trouble
Posted by chadd on April 30, 2007 at 16:39:07 from (155.92.32.116):
In Reply to: Re: B Farmall engine trouble posted by Tracy Gruetzmacher on April 30, 2007 at 11:20:06:
If you replaced the sediment bowl assembly and the screen in it with new ones, I wouldn't bother putting that in-line filter back on. With the sediment bowl, the fine screen in it, and the screen in the carb, the system will have more trash capacity than that filter did. You can hold a LOT more sediment in the old system than the filter can hold without affecting performance. The filter is more or less for those tractors that don't have the screens in anymore. I guess you could keep it for piece of mind, but all it is doing is adding a little more flow restriction, although it is probably scarcely measurable. . .
