Re: 674 brakes
Posted by Fromjb2 on May 01, 2007 at 15:47:08 from (74.101.67.211):
In Reply to: 674 brakes posted by marvin yenglin on May 01, 2007 at 06:45:02:
Hi Marvin, always found it was easier to bleed the brakes when the hydraulic fluid was at operating temperature. Run engine at fast idle about 1100 to 1200 RPM, with clear tubing on bleed screws open bleed screws and let hydraulic oil drain into clean container. Continue bleeding until there are no air bubbles then close bleed screws. Return hydraulic fluid drained to the reservoir. May have to repeat a couple times until all air is out of the system.
JimB
