Re: 4th gear mph?
Posted by georgeky on May 01, 2007 at 18:37:35 from (205.188.116.138):
In Reply to: 4th gear mph? posted by 1850Turbo on May 01, 2007 at 17:23:02:
Using the TA to slow down will ruin the unit eventually. 4th gear in direct drive is fast enough to do what you want. The TA is just for steady pulls such as plowing or other heavy field work. Without a steady pull while the TA is in low the tractor will overrun the unit and cause damage to the roller and ramp set up on the unit. Used properly the TA will last for years, but if you keep using it to slow tractor down and free wheeling it, it will ruin it. Fourth gear will run between 5 and 7 MPH. Again DO NOT USE TA TO SLOW TRACTOR DOWN.
