Re: 400 light switch
Posted by dynaflow on May 02, 2007 at 03:30:42 from (209.251.112.252):
In Reply to: Re: 400 light switch posted by Andy Motteberg on May 01, 2007 at 20:33:17:
Thanks Andy, Just exactley what I needed. David B
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
