Cub Carb leakage
Posted by Gus Campagna on May 02, 2007 at 09:49:31 from (75.13.54.160):
I took off the carb and cleaned it trying to get the tractor running. (It ran good last year)When I put the carb back on with a new gasket, it leaks between the 2 sections of the carb. I have taken it off and put it back on several times and cannot get the leak to stop. It's like it is warped or something. Is it possible to double gasket or put some other gasket in there to stop it or do I need a new carb?
Thanks
Gus
