806 range tranny
Posted by Rich Griffin on May 02, 2007 at 09:58:15 from (71.7.25.193):
Got this tractor,it slips out of hi side. Look through inspection hole{left side}and the collar just touches the hi side teeth. This collar has a wider shoulder on one side than the other. What is the correct way for this slideing collar to be installed? Right now I feel that it is installed wromg.The shift link has been lenghtened about 1/2 inch. The low side is fine. The shift fork shows some wear.
All help appreciated.
Thanks
