Re: magneto for farmall m ?
Posted by PatMz on May 02, 2007 at 19:14:14 from (4.227.234.107):
In Reply to: magneto for farmall m ? posted by james in mo on May 02, 2007 at 16:07:33:
A magneto is good when it works. If you can, park it on "battery hill", any slope that'll get her rolling.
It isn't all that hard to crank, after you get the hang of it. Crank slowly until you feel the compression come up, then pull up clockwise from around the 8 or 9 o'clock position. If she's tuned halfway decent, it should start up in a crank or two.
