Re: magneto for farmall m ?
Posted by old on May 02, 2007 at 20:17:52 from (4.244.219.235):
In Reply to: magneto for farmall m ? posted by james in mo on May 02, 2007 at 16:07:33:
Beleive me a hand crank will get very very old very fast. Plus if all is not right it can or will brake you hand/arm or other things. BTDT. Plus for the cost of a mag you could swithc it to 12 volts or fix your 6 volt system so it makes more since to fix it right in the first place. A good mag will cost you around $200 and you can switch it over to 12 volts for around $100 or less
